Application Viewer Toolbar
The Toolbar provides the main controls for using the Application Viewer. Each button is described below.
Data Dictionary Button
Physical and Logical Buttons
Collapse Button
Attributes and Schema Button
Maintenance Object Button
Algorithm Button
Batch Control Button
To Do Type Button
Description and Code Buttons
Service XML Button
Select Service Button
Java Docs Button
Groovy Java Docs Button
Classic Button
Preferences Button
Help Button
About Button
Slider Icon
Parent topic
Application Viewer
This site works best with JavaScript enabled
