Column Detail View
Click on a column name in the list panel to switch to the column detail view. The Column Detail view displays information about the selected column.
In the column detail view, you can navigate using the following options:
• If user documentation is available for the column, click the View User Documentation link to read about the column's related maintenance object.
• If the column is a foreign key, click the table name to switch to the Table Detail view for that table.
• If the column has a Value List available (normally only present for a subset of flag and switch fields), click the link to view the source code for the copybook (you are transferred to the
Java Docs Viewer).
Parent topic
