Data Dictionary
The data dictionary is an interactive tool that allows you to browse the database schema and to graphically view relationships between tables in the system.
To open the data dictionary, click the Data Dictionary button. You can also open the data dictionary by clicking the name of a table in other parts of the application viewer or in the online help documentation.
Note:Data Is Generated. A background process generated the data dictionary information. Refer to Application Viewer Generation for further details.
