Groovy Java Docs Viewer
The Groovy Java Docs viewer is an interactive tool that allows you to browse Java documentation files (Javadocs) for the Java classes that are accessible to Groovy code within scripts.
For system protection, only a subset of the base Java classes are available for use by Groovy code.
To open the Groovy Java Docs viewer from within the application viewer, click the
Groovy Java Docs button. You can also access the viewer via the ‘View Groovy Javadocs’ link in the context sensitive Script Tips zone. Refer to the additional topics in the
Java Docs Viewer section for details of how to navigate the viewer panels.
Parent topic
