Related Tables View
The Related Tables view displays information about the table's parent tables and child tables. Click the
Schema button in the toolbar to switch to related tables view.
In the related tables view, you can navigate using the following options:
• Click the left arrow and right arrow icons to view the related tables for that linked table. The List Panel is automatically positioned to the selected table.
• Click the maintenance object icon (
![Maintenance Object icon Maintenance Object icon](../CCB_29000/images/91AppViewer056.jpg)
) to view the table's maintenance object.
• If you want to position the
List Panel to view the columns for different table click the name of the table for which you want to view the columns.
Parent topic
