Table Detail View
The table detail view displays information about the selected table. Click Attributes (in the toolbar) to switch to the table detail view.
In the table detail view, you can navigate using the following options:
If user documentation is available for the table, click the View User Documentation link to read the user documentation that describes the table's maintenance object.
If the table has an associated Language Table, click the link to view the Language Table details.
If there is an associated Maintenance Program, click the link to view the source code for the maintenance program (you are transferred to the Java Docs Viewer).
If there is an associated Key Table, click the link to view the Key Table details.
