Business Service - Main
Use this page to define basic information about a Business Service. Open this page using Admin > System > Business Service
Use the Business Service Query portal to search for an existing business service. Once a business service is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Enter a unique Business Service name and Description. Use the Detailed Description to describe the purpose of this business service in detail. Owner indicates if the business service is owned by the base package or by your implementation (Customer Modification).
CAUTION:
Important! If you introduce a new business service, carefully consider its naming convention. Refer to System Data Naming Convention for more information.
Enter the internal Service Name being called when this business service is invoked.
Enter the Application Service that is used to provide security for the business service. The application service must have an Access Mode of Execute.
Click the View Schema to view the business service's expanded schema definition. Doing this opens the schema viewer window.
Click the View XSD hyperlink to view the business object's expanded schema definition in XSD format.
