Some Portals Allow User Customization
There are some portals in each base product that are configured to allow user customization. In this case, the portal is visible on the user's portal preferences. For these portals each user has control over the following:
• Which zones appear on their portal
• The order in which the zones appear
• Whether the zones should be "collapsed" (i.e., minimized) when the portal opens.
Users define their preferences by clicking the
User Preferences button. Pressing this button transfers the user to the
User Preferences page on which their
Portal Preferences can be defined.
Portals used for base product query and maintenance pages are typically configured to not allow user customization.
Parent topic
