Favorite Scripts Zone
The Favorite Scripts zone lists the business process assistant (BPA) scripts that you have defined on your
user preferences. You can click on a script to
execute it. You can click the
Search button in the zone to search for other scripts.
If you do not see the Favorite Scripts zone in your dashboard, navigate to User Menu and click the
Preferences menu item to display the
User - Portal Preferences page. Under the Dashboard Portal row, select the
Display option for the Favorite Scripts zone.
Parent topic
