Map Zones
A map zone displays information related to one or more objects. For objects that are maintained using portal-based pages, the standard display of the object is using a map zone. Map zones may be configured to display an explicit map or may dynamically display the map based on the configuration of the record being displayed.
Because the information displayed in a map zone is configured using HTML, virtually any format supported by HTML is possible. The following is an example of a typical map zone used to display information about an object.
![Sample Map Zone Sample Map Zone](../CCB_29000/images/BP01SWS_Delete_Button_object_map.jpg)
A
tool tip can be used to display additional help information for the details shown in a map zone. The tool tip may appear adjacent to the section header or adjacent to individual elements on a map.
You can customize the help icon or disable map help using the
Custom Look and Feel feature configuration.
Parent topic
