Field Activities Initiated To Start Service
Use the customer event Start to define the field activity(s) used to start service at a service point whose SP type references this profile.
Description of Page
See Field Activity Type Profile - Template for a description of the fields.
Where Used
The start service process uses this information to determine the type of field activities to create to start service at a service point.
Warning:
Warning. Field activities will only be created for starts if you have defined the appropriate field work creation algorithm on the service agreement's SA type. Refer to SA Type - Algorithms for more information.
