Field Activities Initiated To Stop Service
Use the customer event Stop to define the field activity(s) used to stop service at a service point whose SP type uses this profile.
Description of Page
See Field Activity Type Profile - Template for a description of the fields.
Where Used
The stop service process uses this information to determine the type of field activities to create to stop service at a service point.
Warning:
Warning. Field activities will only be created for stops if you have defined the appropriate field work creation algorithm on the service agreement's SA type. Refer to SA Type - Algorithms for more information.
