Adjustment Type - Adjustment Characteristics
To define characteristics that can be defined for adjustments of a given type, open Adjustment Characteristics page.
and navigate to theDescription of Page
Use the Adjustment Characteristics collection to define characteristics that can be defined for adjustments of a given type. Turn on the Required switch if the Characteristic Type must be defined on adjustments of a given type. Enter a Characteristic Value to use as the default for a given Characteristic Type when the Default switch is turned on. Use Sequence to control the order in which characteristics are defaulted.
