SA Types And The Financial Design
In this section, we provide an example of how our SA Types map to Bill Segment Types, Payment Segment Types, and Adjustment Profiles. This example is meant to help solidify the power of the financial model, it is not necessarily indicative of how your specific implementation will look.
If you are not comfortable with the topics described in Defining Financial Transaction Options, the following table will not make sense.
Division/SA Type |
Distribution Code |
Bill Segment Type |
Payment Segment Type |
Adjustment Profiles |
CA/G-RES |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES, BUDGET |
CA/G-COM |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/G-IND |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/W-RES |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/W-COM |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/W-IND |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/E-RES |
A/R-UTIL |
SP-RATED |
NORMAL |
CA/E-COM |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/E-IND |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/WW-RES |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/WW-COM |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/WW-IND |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/CABLE |
A/R-UTIL |
SP-RATED |
NORMAL |
BALXFER, MISCFEES |
CA/E-COY |
E-COMP |
COMPUSAG |
CA/G-COY |
E-COMP |
COMPUSAG |
CA/W-COY |
E-COMP |
COMPUSAG |
CA/WO-STD |
NORMAL |
BALXFER |
CA/WO-LIA |
NORMAL |
BALXFER |
CA/CONNECT |
NORMAL |
BALXFER, MISCFEES |
CA/CHARITY |
A/P-CHAR |
RECUR |
CHARITY |
CHARITY |
CA/PA-REGU |
A/R-ARRG |
RECUR-AS |
NORMAL |
BALXFER, MISCFEES, DPA |
CA/PA-UNRE |
A/R-ARRG |
RECUR-AS |
NORMAL |
CA/MERCH-I |
A/R-MRCH |
RECUR-AS |
NORMAL |
BALXFER, MISCFEES, MERCH |
CA/DEP-I |
A/P-DEPO |
RECUR-AS |
NORMAL |
BALXFER, MISCFEES, DEPOSIT |
CA/ONETIME |
A/R-UTIL |
BILLCHRG |
NORMAL |
BALXFER, MISCFEES |
CA/OVR UNDR |
EXP-OV/UND |
NORMAL |
CA/OVERPAY |
A/P-OVER |
NORMAL |
BALXFER |
CA/SUSPENSE |
A/R-SUSP |
NORMAL |
CA/NBB |
A/P-OVPY |
NORMAL |
BALXFER, MISCFEES, NBB |
If you operate in a deregulated environment, you will also have additional SA types as described under Designing Your SA Types And Start Options For Sub SAs and Designing SA Types For Service Provider Financial Settlements you may have additional SA types.
