TOU Pricing Calc Details - SA Information
To navigate to this page, you must first go to
and display a bill segment with TOU data in its calculation lines. From the Calc Lines tab, you may choose to audit a bill line that is the result of a TOU pricing rate component that has an audit algorithm. Once on the Calc Details page, you may navigate to the SA Information tab.Description of Page
The top section of this page is the same as the main page.
This page displays two tree structures. The first tree structure shows the interval profiles found for this SA and interval profile relationship type for this time period. The second tree structure is only visible if the rate component references a classic TOU map relationship type. It shows the classic TOU maps found for this SA and classic TOU map relationship type for this time period.
