Configuration Properties
This appendix lists the configurations stored in the OUC2MOUNMSConfigurationProperties.xml file located under the apps/C2M-NMS/AIAMetaData/config directory.
For information about modifying configuration properties, refer to the “Setting Configuration Properties” section in Chapter 3: Configuration Guidelines.
Two types of configuration properties are managed in the configuration files:
• Module Configurations: Module configurations are the properties that are shared by multiple processes within this integration.
• Service Configurations: Service configurations are the properties that are used by a specific ABCS.
