Domain Value Maps (DVMs)
The following table lists the DVMs included for the integration.
For information on creating DVMs refer to the “Setting Domain Value Maps” section in Chapter 3: Configuration Guidelines.
For more information about on working with DVMs, see the section “Working with Domain Value Maps” in Oracle Fusion Middleware Developing SOA Applications with Oracle SOA Suite documentation.
DVM
Integration Points
Description
C2M/NMS Values
OUC2M_OUNMS_AccountType
Customer Data Synchronization
DVM mapping for C2M Service Type Code to the to NMS Account Type.
OUC2M_ServiceType - This contains the valid C2M values for 'Service Type'.
OUNMS_AccountType - This contains the valid NMS values for 'Account Type'.
OUC2M_OUNMS_Alarm_State
Job History Query
DVM mapping for Alarm State Code
OUC2M_ Alarm_State - This contains the valid C2M values for 'Alarm State'. These values are obtained from C2M lookup C1_ALARM_STATE_FLG.
OUNMS_ Alarm_State - This contains the valid NMS values for 'Alarm State'.
OUC2M_OUNMS_Call_Status
Trouble Call History Query
DVM mapping for Call Status Code
OUC2M_Call_Status - This contains the valid C2M values for 'Call Status'. These values are obtained from C2M lookup C1_CALL_STATUS_FLG.
OUNMS_Call_Status - This contains the valid NMS values for 'Call Status'.
OUC2M_OUNMS_CallBackIndicator
Trouble Call Interface
DVM mapping for Call Back Indicator
OUC2M_ CallbackRequested - This contains the valid C2M values for 'Callback Requested'.
OUNMS_CallbackFlag - This contains the valid NMS values for 'Callback Flag'.
OUC2M_OUNMS_
CallCancelIndicator
DVM mapping for Call Cancel Indicator
OUC2M_Status - This contains the valid C2M values for 'Call Cancel'.
OUNMS_ CallCancelFlag - This contains the valid NMS values for 'Call Cancel Flag'.
OUC2M_OUNMS_Cause
Job History Query
DVM mapping for Cause Code
OUC2M_Cause - This contains the valid C2M values for 'Cause'.
OUNMS_CauseFlag- This contains the valid NMS values for 'Cause Flag'.
OUC2M_OUNMS_ETR_Source
Job History Query
DVM mapping for ETR Source Code
OUC2M_ ETR_Source - This contains the valid C2M values for 'ETR Source'. These values are obtained from C2M lookup C1_ETR_SOURCE_FLG.
OUNMS_ ETR_Source - This contains the valid NMS values for 'ETR Source'.
OUC2M_OUNMS_Job_History_
Status
Job History Query
DVM mapping for Job History Status Code
OUC2M_ Job_History_Status - This contains the valid C2M values for 'ETR Source'. These values are obtained from C2M lookup C1_ETR_SOURCE_FLG
OUNMS_ Job_History_Status - This contains the valid NMS values for 'Job History Status'.
OUC2M_OUNMS_
LifeSupportIndicator
DVM mapping for Life Support Indicator
OUC2M_ LifeSupportIndicator - This contains the valid C2M values for 'Life Support Indicator'.
OUNMS_ LifeSupportIndicator - This contains the valid NMS values for 'Life Support Indicator'.
OUC2M_OUNMS_MeetType
DVM mapping for Meet Type Code
OUC2M_MeetType - This contains the valid C2M values for 'Meet Type'.
OUNMS_MeetType - This contains the valid NMS values for 'Meet Type'.
OUC2M_OUNMS_MeterType
DVM mapping for Meter Type Code
OUC2M_MeterType - This contains the valid C2M values for 'Meter Type'.
OUNMS_MeterType - This contains the valid NMS values for 'Meet Type'.
OUC2M_OUNMS_NewCallIndicator
DVM mapping for New Call Indicator
OUC2M_ OutageCallAction - This contains the valid C2M values for 'Outage Call Action Flag'. These values are obtained from C2M lookup C1_OUTCALL_ACT_FLG.
OUNMS_ UpdateExistingFlag - This contains the valid NMS values for 'Update Existing Flag'.
OUC2M_OUNMS_Serv_C_Priority
DVM mapping for Critical Priority Code
OUC2M_ Serv_C_Priority - This contains the valid C2M values for 'Serv C Priority'.
OUNMS_ Serv_C_Priority - This contains the valid NMS values for 'Serv C Priority'
OUC2M_OUNMS_Serv_D_Priority
DVM mapping for Medical Priority Code
OUC2M_ Serv_D_Priority - This contains the valid C2M values for 'Serv D Priority'.
OUNMS_ Serv_D_Priority - This contains the valid NMS values for 'Serv D Priority'
OUC2M_OUNMS_Serv_K_Priority
DVM mapping for Key Priority Code
OUC2M_ Serv_K_Priority - This contains the valid C2M values for 'Serv K Priority'.
OUNMS_ Serv_K_Priority - This contains the valid NMS values for 'Serv K Priority'
OUC2M_OUNMS_Instance
• Customer Data Sync
• Submit trouble call
• Query Job history
• Query trouble call
• Planned outage
OUC2M_CISDivision - This contains the valid C2M CIS Division.
OUNMS_BaseURL - This contains the valid baseURL value pointing to the NMS instance for the CIS Division.
Example: https://NMS_HOST.yourdomain.com:NMS_PORT_NO
OUC2M_OUNMS_Serv_A_Priority
OUC2M_ Serv_A_Priority - This contains the valid C2M values for 'Serv A Priority'.
OUNMS_ Serv_A_Priority - This contains the valid NMS values for 'Serv A Priority'
OUC2M_OUNMS_Serv_B_Priority
OUC2M_ Serv_B_Priority - This contains the valid C2M values for 'Serv B Priority'.
OUNMS_ Serv_B_Priority - This contains the valid NMS values for 'Serv B Priority'
OUC2M_OUNMS_Serv_E_Priority
OUC2M_ Serv_E_Priority - This contains the valid C2M values for 'Serv E Priority'.
OUNMS_ Serv_E_Priority - This contains the valid NMS values for 'Serv E Priority'
OUC2M_OUNMS_Serv_F_Priority
OUC2M_ Serv_F_Priority - This contains the valid C2M values for 'Serv F Priority'.
OUNMS_ Serv_F_Priority - This contains the valid NMS values for 'Serv F Priority'
OUC2M_OUNMS_Serv_G_Priority
OUC2M_ Serv_G_Priority - This contains the valid C2M values for 'Serv G Priority'.
OUNMS_ Serv_G_Priority - This contains the valid NMS values for 'Serv G Priority'
OUC2M_OUNMS_Serv_H_Priority
OUC2M_ Serv_H_Priority - This contains the valid C2M values for 'Serv H Priority'.
OUNMS_ Serv_H_Priority - This contains the valid NMS values for 'Serv H Priority'
OUC2M_OUNMS_Serv_I_Priority
OUC2M_ Serv_I_Priority - This contains the valid C2M values for 'Serv I Priority'.
OUNMS_ Serv_I_Priority - This contains the valid NMS values for 'Serv I Priority'
OUC2M_OUNMS_Serv_J_Priority
OUC2M_ Serv_J_Priority - This contains the valid C2M values for 'Serv J Priority'.
OUNMS_ Serv_J_Priority - This contains the valid NMS values for 'Serv J Priority'
OUC2M_OUNMS_Serv_L_Priority
OUC2M_ Serv_L_Priority - This contains the valid C2M values for 'Serv L Priority'.
OUNMS_ Serv_L_Priority - This contains the valid NMS values for 'Serv L Priority'
OUC2M_OUNMS_Serv_M_Priority
OUC2M_ Serv_M_Priority - This contains the valid C2M values for 'Serv M Priority'.
OUNMS_ Serv_M_Priority - This contains the valid NMS values for 'Serv M Priority'
OUC2M_OUNMS_Serv_N_Priority
OUC2M_ Serv_N_Priority - This contains the valid C2M values for 'Serv N Priority'.
OUNMS_ Serv_N_Priority - This contains the valid NMS values for 'Serv N Priority'
OUC2M_OUNMS_Serv_O_Priority
OUC2M_ Serv_O_Priority - This contains the valid C2M values for 'Serv O Priority'.
OUNMS_ Serv_O_Priority - This contains the valid NMS values for 'Serv O Priority'
OUC2M_OUNMS_Serv_P_Priority
OUC2M_ Serv_P_Priority - This contains the valid C2M values for 'Serv P Priority'.
OUNMS_ Serv_P_Priority - This contains the valid NMS values for 'Serv P Priority'
OUC2M_OUNMS_Serv_Q_Priority
OUC2M_ Serv_Q_Priority - This contains the valid C2M values for 'Serv Q Priority'.
OUNMS_ Serv_Q_Priority - This contains the valid NMS values for 'Serv Q Priority'
OUC2M_OUNMS_Serv_R_Priority
OUC2M_ Serv_R_Priority - This contains the valid C2M values for 'Serv R Priority'.
OUNMS_ Serv_R_Priority - This contains the valid NMS values for 'Serv R Priority'
OUC2M_OUNMS_Serv_S_Priority
OUC2M_ Serv_S_Priority - This contains the valid C2M values for 'Serv S Priority'.
OUNMS_ Serv_S_Priority - This contains the valid NMS values for 'Serv S Priority'
OUC2M_OUNMS_Serv_T_Priority
OUC2M_ Serv_T_Priority - This contains the valid C2M values for 'Serv T Priority'.
OUNMS_ Serv_T_Priority - This contains the valid NMS values for 'Serv T Priority'
OUC2M_OUNMS_Serv_U_Priority
OUC2M_ Serv_U_Priority - This contains the valid C2M values for 'Serv U Priority'.
OUNMS_ Serv_U_Priority - This contains the valid NMS values for 'Serv U Priority'
OUC2M_OUNMS_Serv_V_Priority
OUC2M_ Serv_V_Priority - This contains the valid C2M values for 'Serv V Priority'.
OUNMS_ Serv_V_Priority - This contains the valid NMS values for 'Serv V Priority'
OUC2M_OUNMS_Serv_X_Priority
OUC2M_ Serv_X_Priority - This contains the valid C2M values for 'Serv X Priority'.
OUNMS_ Serv_X_Priority - This contains the valid NMS values for 'Serv X Priority'
OUC2M_OUNMS_Serv_Y_Priority
OUC2M_ Serv_Y_Priority - This contains the valid C2M values for 'Serv Y Priority'.
OUNMS_ Serv_Y_Priority - This contains the valid NMS values for 'Serv Y Priority'
OUC2M_OUNMS_Serv_Z_Priority
OUC2M_ Serv_Z_Priority - This contains the valid C2M values for 'Serv Z Priority'.
OUNMS_ Serv_Z_Priority - This contains the valid NMS values for 'Serv Z Priority'
