Module Configurations
Module Configurations have application level properties which are used by all the SOA composites.
Note: When the DVM lookup value is not found for a DVM, DVM flags signal if an error is triggered. If the value is set to "true", the integration layer triggers a DVM exception to the initiating application. If the value is set to "false", the integration does not trigger any exception and it passes the source application value as the default value to the target application.
Module Name
Default
Description
CCB.Generic.MessageCategory
11017
This is the message category that the integration layer uses for Oracle Utilities Customer Care and Billing error messages.
CCB.GenericBusinessException.MessageNumber
11001
This is the message number that the integration layer uses for generic Oracle Utilities Customer Care and Billing errors.
CCB.GenericDVMException.MessageNumber
11401
This is the message number that the integration layer uses for DVM errors.
SOA-INFRA.AuditLevel
ON
This property needs to be set to OFF if the Audit Level is set to OFF for the BPEL processes. If the setting is OFF, then error handling does not use the composite and component instance IDs to log the error message.
ErrorHandling.GenericEmailID
This property is used to set the administrator email ID for the errorhandling process to send out an email if a critical failure occurs where even the Errorhandling process fails.
DVM.OUCCB2_OUMDM2_MO.ThrowException
false
Flag for OUCCB2_OUMDM2_MO DVM.
DVM.OUCCB2_OUMDM2_ContactType.ThrowException
false
Flag for OUCCB2_OUMDM2_ContactType DVM.
DVM.OUCCB2_OUMDM2_Country.ThrowException
false
Flag for OUCCB2_OUMDM2_Country DVM.
DVM.OUCCB2_OUMDM2_DisconnectLocation.Throw
Exception
false
Flag for OUCCB2_OUMDM2_DisconnectLocation DVM.
DVM.OUCCB2_OUMDM2_MeasurementCycle.Throw
Exception
false
Flag for OUCCB2_OUMDM2_MeasurementCycle DVM.
DVM.OUCCB2_OUMDM2_MeasurementCycleRoute.Throw
Exception
false
Flag for OUCCB2_OUMDM2_MeasurementCycleRoute DVM.
DVM.OUCCB2_OUMDM2_SPSourceStatus.ThrowException
false
Flag for OUCCB2_OUMDM2_SPSourceStatus DVM.
DVM.OUCCB2_OUMDM2_SPStatus.ThrowException
false
Flag for OUCCB2_OUMDM2_SPStatus DVM.
DVM.OUCCB2_OUMDM2_SPType.ThrowException
false
Flag for OUCCB2_OUMDM2_SPType DVM.
DVM.OUCCB2_OUMDM2_LifeSupportSensitiveLoad
.ThrowException
false
Flag for OUCCB2_OUMDM2_LifeSupportSensitiveLoad DVM.
DVM.OUCCB2_OUMDM2_USType.ThrowException
false
Flag for OUCCB2_OUMDM2_USType DVM.
DVM.OUCCB2_OUMDM2_SAStatus.ThrowException
false
Flag for OUCCB2_OUMDM2_SAStatus DVM.
DVM.OUCCB2_OUMDM2_DeviceType.ThrowException
false
Flag for OUCCB2_OUMDM2_DeviceType DVM.
DVM.OUCCB2_OUMDM2_MeterStatus.ThrowException
false
Flag for OUCCB2_OUMDM2_MeterStatus DVM.
DVM.OUCCB2_OUMDM2_Manufacturer.ThrowException
false
Flag for OUCCB2_OUMDM2_Manufacturer DVM.
DVM.OUCCB2_OUMDM2_Model.ThrowException
false
Flag for OUCCB2_OUMDM2_Model DVM.
DVM.OUCCB2_OUMDM2_DeviceConfigType.Throw
Exception
false
Flag for OUCCB2_OUMDM2_DeviceConfigType DVM.
DVM.OUCCB2_OUMDM2_HowToUse.ThrowException
false
Flag for OUCCB2_OUMDM2_HowToUse DVM.
DVM.OUCCB2_OUMDM2_ReadOutType.ThrowException
false
Flag for OUCCB2_OUMDM2_ReadOutType DVM.
DVM.OUCCB2_OUMDM2_ConsumptiveSubtractive.Throw
Exception
false
Flag for OUCCB2_OUMDM2_ConsumptiveSubtractive DVM.
DVM.OUCCB2_OUMDM2_MCServiceType.ThrowException
false
Flag for OUCCB2_OUMDM2_MCServiceType DVM.
DVM.OUCCB2_OUMDM2
_NegativeConsumption.ThrowException
false
Flag for OUCCB2_OUMDM2_NegativeConsumption DVM.
DVM.OUCCB2_OUMDM2_BillCondition.ThrowException
false
Flag for OUCCB2_OUMDM2_BillCondition DVM.
DVM.OUCCB2_OUMDM2_AllowEstimate.ThrowException
false
Flag for OUCCB2_OUMDM2_AllowEstimate DVM.
DVM.OUCCB2_OUMDM2_BillingOption.ThrowException
false
Flag for OUCCB2_OUMDM2_BillingOption DVM.
DVM.OUCCB2_OUMDM2_BillMode.ThrowException
false
Flag for OUCCB2_OUMDM2_BillMode DVM.
DVM.OUCCB2_OUMDM2_AutomatedRetry.ThrowException
false
Flag for OUCCB2_OUMDM2_AutomatedRetry DVM.
DVM.OUMDM2_OUCCB2_IsEstimate.ThrowException
false
Flag for OUMDM2_OUCCB2_IsEstimate DVM.
DVM.OUMDM2_OUCCB2_UOM.ThrowException
false
Flag for OUMDM2_OUCCB2_UOM DVM.
DVM.OUMDM2_OUCCB2_TOU.ThrowException
false
Flag for OUMDM2_OUCCB2_TOU DVM.
DVM.OUMDM2_OUCCB2_SQI.ThrowException
false
Flag for OUMDM2_OUCCB2_SQI DVM.
DVM.OUMDM2_OUCCB2_UsageType.ThrowException
false
Flag for OUMDM2_OUCCB2_UsageType DVM.
DVM.OUMDM2_OUCCB2_MeasuresPeakQuantity.Throw
Exception
false
Flag for OUMDM2_OUCCB2_MeasuresPeakQuantity DVM.
DVM.OUMDM2_OUCCB2_SPHowToUse.ThrowException
false
Flag for OUMDM2_OUCCB2_SPHowToUse DVM.
DVM.OUMDM2_OUCCB2_SkipSA.ThrowException
false
Flag for OUMDM2_OUCCB2_SkipSA DVM.
DVM.OUMDM2_OUCCB2_SkipReason.ThrowException
false
Flag for OUMDM2_OUCCB2_SkipReason DVM.
DVM.OUCCB2_OUMDM2_ReadType.ThrowException
false
Flag for OUCCB2_OUMDM2_ReadType DVM.
DVM.OUMDM2_OUCCB2_Estimation
Indicator.ThrowException
false
OUMDM2_OUCCB2_EstimationIndicator.dvm
DVM.OUMDM2_OUCCB2_HighlightType.ThrowException
false
OUMDM2_OUCCB2_HighlightType.dvm
DVM.OUMDM2_OUCCB2_ItemType.ThrowException
false
OUMDM2_OUCCB2_ItemType.dvm
