Service Configurations
Service Configuration properties are specific to SOA composites. These are used to make changes in specific composite behavior.
Service Name
Property Name
Default / Shipped Value
Description
All of the service names in the configuration properties file will have these two property names to control email notifications on errors.
BusinessError.NotificationFlag
false
If set to true, business error notification is sent via Email.
TechnicalError.NotificationFlag
false
If set to true, technical error notification is sent via Email.
Person Information Synchronization Integration Process
OUCCB2OUMDM2PersonSyncReqEBF
Default.SystemID
OU_CCB2_01
Initiating system ID.
Extension.PreXform
CCB2toMDM2
false
If set to true, the pre transformation extension service is invoked.
Extension.PostXformToMDM2
false
If set to true, the post transformation extension service is invoked.
OUMDM2OUCCB2PersonSyncRespEBF
Default.SystemID
OU_MDM2_01
Extension.PreXformMDM2toCCB2
false
Extension.PostXformtoCCB2
false
SP Information Synchronization Integration Process
OUCCB2OUMDM2SPSyncReqEBF
Default.SystemID
OU_CCB2_01
Extension.PreXformCCB2toMDM2
false
false
OUMDM2OUCCB2SPSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
SA Information Synchronization Integration Process
OUCCB2OUMDM2SASyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2SASyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
SA Relationship Information Synchronization Integration Process
OUCCB2OUMDM2SARelationshipSyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2SARelationshipSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
Meter Information Synchronization Integration Process
OUCCB2OUMDM2MeterSyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2MeterSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
SP-Meter History Information Synchronization Integration Process
OUCCB2OUMDM2SPMeterHistSyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2SPMeterHistSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
Meter Configuration Information Synchronization Integration Process
OUCCB2OUMDM2MeterConfigSyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
MDM2.Inverval.Flag
D1IN
Flag for Interval meter
MDM2.Scalar.Flag
D1SC
Flag for Scalar meter
OUMDM2OUCCB2MeterConfigSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
Batch Bill Determinants Integration Process
OUCCB2OUMDM2BatchBDReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2BatchBDRespEBF
Default.SystemID
OU_MDM2_01
false
false
Online Bill Determinants Integration Process
OUCCB2OUMDM2OnlineBDReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2OnlineBDRespEBF
Default.SystemID
OU_MDM2_01
false
false
Replacement Reads Integration Process
OUMDM2OUCCB2ReplReadReqEBF
Default.SystemID
OU_MDM2_01
false
false
Scalar Meter Read Sync Integration Process
OUCCB2OUMDM2MeterReadSyncReqEBF
Default.SystemID
OU_CCB2_01
false
false
OUMDM2OUCCB2MeterReadSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
Get Register Read High-Low Boundaries Integration Process
OUCCB2OUMDM2HighLowReadReqEBF
Default.SystemID
OU_CCB2_01
false
Extension.PostXformCCB2toMDM2
false
If set to true, the post transformation extension service is invoked before invoking MDM.
false
If set to true, the pre transformation extension service for Resposne is invoked.
Extension.PostXformMDM2toCCB2
false
If set to true, the post transformation extension service for Response is invoked.
MDM2.DetermineHighLowReads.Endpoint.URL
@mdm_protocol://@mdm_host:@mdm_port/@mdm_ctx1/D2-DetermineEstimatedAndHighLowScalar
Readings
This value is the MDM Service Determine High/Low Reads endpoint URL.
Get Usage Request Integration Process
OUCCB2OUMDM2SSUsageReqEBF
Default.SystemID
OU_CCB2_01
false
If set to true, the pre transformation extension service for the request message is invoked.
false
If set to true, the post transformation extension service for the request message is invoked.
false
If set to true, the pre transformation extension service for the response message is invoked.
false
If set to true, the post transformation extension service for the response message is invoked.
MDM2.D2CalculateUsage
MultipleRequest.Endpoint.URL
@mdm_protocol://@mdm_host:@mdm_port/@mdm_ctx1/D2-CalculateUsageMultipleRequests
This value is the MDM Service Calculate Usage Calculate Usage Multiple Request Endpoint URL.
During install, the MDM edge application information is tokenized to point to the correct MDM server being used.
Usage Adjustment Request Integration Process
OUCCB2OUMDM2SSUsageAdjustmentReqEBF
Default.SystemID
OU_CCB2_01
false
false
false
false
MDM2.WX-UsageAdjustmentRetrieval.Endpoint.URL
@mdm_protocol://@mdm_host:@mdm_port/@mdm_ctx1/D2-UsageAdjustment
Retrieval
This value is the MDM Service WX-UsageAdjustmentRetrieval Endpoint URL.
Contract Option Event /Dynamic Option Event Synchronization Integration Process
OUCCB2OUMDM2DynamicOptEvtSyncReqEBF
Default.SystemID
OU_CCB2_01
Override.Request
false
If set to true, the override request transformation is executed.
Contract Option/Dynamic Option Synchronization Integration Process
OUMDM2OUCCB2DynamicOptEvtSyncRespEBF
Default.SystemID
OU_MDM2_01
Override.Request
false
Bill Cycle Synchronization Integration Process
OUCCB2OUMDM2BillCycleSyncReqEBF
Default.SystemID
OU_CCB2_01
Extension.PreXform
CCB2toMDM2
false
false
OUCCB2OUMDM2BillCycleSyncRespEBF
Default.SystemID
OU_MDM2_01
false
false
SA Activation Bill Cycle Request Integration Process
OUCCB2OUMDM2SAActivationBillCycleRequestEBF
Default.SystemID
OU_CCB2_01
false
false
false
false
MDM2.D2-DetermineBillCycleForSP.EndpointURL
@mdm_protocol://@mdm_host: @mdm_port/@mdm_ctx1 /D2-UsageAdjustment
Retrieval
This value is the MDM Service D2-DetermineBillCycleForSP Endpoint URL.
Bill Cycle Change Notification Integration Process
OUMDM2OUCCBBillCycleChangeNotifEBF
Default.SystemID
OU_MDM2_01
false
false
CCB2.C1BillCycleUpdateNotification.Endpoint.URL
@ccb_protocol://@ccb_host@ccb_port/@ccb_ctx1/C1-BillCycleUpdateNotification
This value is the CCB Service Bill Cycle UpdateNotification Endpoint URL.
During install, the CCB edge application information is tokenized to point to the correct CCB server being used.
Usage Transaction Info Update Integration Process
OUCCB2OUMDM2UpdateUTInfoEBF
Default.SystemID
OU_CCB2_01
MDM2.DetermineUpdateUTInfo.Endpoint URL
@mdm_protocol://@mdm_host:@mdm_port/ @mdm_ctx1/D2-UsageTransactionUpdateInbound
This value is the MDM Usage Transaction Request Inbound Endpoint URL.
