Deploying the MDS Folder
Perform the following steps to deploy the MDS folder:
1. Open a command prompt and execute the following commands in Linux and Windows respectively:
Linux
cd $PRODUCT_HOME/bin
ant -f DeployUndeployUtility.xml -DInstallProperties=$PRODUCT_HOME/config/InstallProperties.xml DeployMDS
Windows
cd %PRODUCT_HOME%\bin
ant -f DeployUndeployUtility.xml -DInstallProperties=%PRODUCT_HOME%\
config\InstallProperties.xml DeployMDS
2. Validate the MDS Folder Name parameter when prompted with default values during deployment.
3. Press ENTER to use the default value.
DVM Changes
When new DVM values are added to a DVM file, the DVM folder must be updated in MDS. This command will not only deploy the files that were changed but also the entire DVM folder.
• Pass /AIAMetaData/dvm as the MDS Folder Name and the entire DVM folder will deploy to MDS.
• When the DVMs are updated from the SOA composer, verify that the values are updated in the /MDS-Artifacts/CCB2-MDM2/AIAMetaData/dvm folder.
If not, the changes made from the composer will be overridden by the PRODUCT_HOME values.
Custom Schema Changes
If custom elements are added to either or both of the edge application schemas, the ApplicationObjectLibrary folder must be updated in MDS.
Do one of the following:
• Pass CCB2-MDM2/AIAMetaData/AIAComponents/ApplicationObjectLibrary to deploy the schema folders, or
• Pass CCB2-MDM2/AIAMetaData/AIAComponents/ApplicationObjectLibrary/OUCCB2 to deploy only the CCB schema folder, or
• Replace CCB with MDM to deploy only the MDM schema folder.
Concrete WSDL Changes for Extensions
If an extension service needs to be called by a process and the concrete WSDL is updated, the ExtensionServiceLibrary folder must be updated in MDS.
Do any of the following:
• Pass CCB2-MDM2/AIAMetaData/ApplicationObjectLibrary/ExtensionServiceLibrary to deploy the extension service library folders, or
• Pass /AIAMetaData/ApplicationObjectLibrary/ to deploy only the extension library folder, or
• Replace CCB with MDM to deploy only the MDM extension service library.
