Supported Source Applications
The following table shows the source application versions supported in this integration:
Application
Version
Oracle Utilities Customer Care and Billing
25.4, 2.9.0.x, 2.8.0.x
Oracle Utilities Meter Data Management
25.4, 2.5.0.x, 2.4.0.x
Oracle SOA Suite
14c (14.1.2.0.0)
Oracle Enterprise Manager
14.1.2.0.0
WebLogic Server
14.1.2.0.0
Refer to the
Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1)
on
My Oracle Support
to determine if support for newer versions of the listed products is included.
This site works best with JavaScript enabled
