Module Configurations
Module Configurations have application level properties which are used by all the SOA composites.
Module Name
Property Name
Default /
Shipped
Value
Description
CCB-NMS
CCB.Generic.MessageCategory
11114
This is the Message category that the integration uses for CCB Error messages.
CCB-NMS
CCB.GenericBusinessException
.MessageNumber
11001
This is the Message number the integration uses for Generic CCB error.
CCB-NMS
CCB.GenericDVMException
.MessageNumber
11401
This is the Message number the integration uses for DVM error.
CCB-NMS
SOA-INFRA.AuditLevel
ON
This property needs to be set to OFF if the Audit Level is set to off for the BPEL processes. If this is set to OFF the Error Handling does not use the composite and component instance IDs to log the error message.
CCB-NMS
ErrorHandling.GenericEmailID
This property is used to set the administrator email ID for the errorhandling process to send out an email in case of a critical failure where even the Errorhandling process fails.
CCB-NMS
DVM.OUCCB_OUNMS_ETR_SOURCE
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM OUCCB_OUNMS_ETR_SOURCE.
If set to true, the integration triggers a DVM exception error to the initiating application.
If set to false, the integration does not trigger any exception and instead passes the source application value as the default value to the target application.
CCB-NMS
DVM.OUCCB_OUNMS_Job_History_Status
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM OUCCB_OUNMS_Job_History_Status.
CCB-NMS
DVM.OUCCB_OUNMS_Alarm_State
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM OUCCB_OUNMS_Alarm_State.
CCB-NMS
DVM.OUCCB_OUNMS_CALL_STATUS
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM OUCCB_OUNMS_CALL_STATUS.
CCB-NMS
DVM.OUCCB_OUNMS_CallBackIndicator
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM OUCCB_OUNMS_CallBackIndicator.
CCB-NMS
DVM.OUCCB_OUNMS_MeetType
.ThrowException
false
This flag indicates if an error is triggered when the DVM lookup value is not found for DVM.
CCB-NMS
DVM.OUCCB_OUNMS_NewCallIndicator
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_CallCancelIndicator
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_AccountType
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_MeterType
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_Serv_C_Priority
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_Serv_D_Priority
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_Serv_K_Priority
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_LifeSupportIndicator
.ThrowException
false
CCB-NMS
DVM.OUCCB_OUNMS_ErrorCode
.ThrowException
false
This flag is not used by the integration.
CCB-NMS
_FALSE_VALUE
0
This is the NMS value for life support if it is false.
CCB-NMS
_TRUE_VALUE
1
This is the NMS value for life support if it is true. This value is used to verify that the CCB life support value in the premise info or person info is true then the NMS value has to be set to true.
