Installation Properties
The following table lists the properties available in the InstallProperties.xml file along with their usage. The default values are specified wherever applicable.
Property (XPath Representation)
Description
Example
SOA Information
<config>
<config><modulename>
Name of the integration module.
Default: CCB-NMS
Do not change this value.
CCB Application Information
<CCB-NMS><CCB><protocol>
The protocol on which the application is accessible.
http or https
<CCB-NMS><CCB><host>
The host name of Oracle Utilities Customer Care and Billing server application.
CCB_HOST.yourdomain.com
<CCB-NMS><CCB><port>
The port number of Oracle Utilities Customer Care and Billing application.
CCB_PORT_NO (Example: 1961)
<CCB-NMS><CCB><contextRoot>
The context root of the application.
CCB_CONTEXT_ROOT
_NAME
ouaf/XAIApp/xaiserver (for XAI services)
ouaf/webservices (for IWS services)
<CCB-NMS><CCB><policy>
The security policy that CCB
accepts when invoking it’s webservice.
Use oracle/ wss_http_token_client_policy for XAI services or refer to the Security Policies section for more information when invoking IWS services.
<CCB-NMS><CCB><ApplicationUsername>
The login user name of the application.
CCBUSER
<CCB-NMS><CCB><ApplicationPassword>
The login password of the application.
CCBPWD
NMS Application Information
<CCB-NMS><NMS><ApplicationUsername>
NMSUSER
<CCB-NMS><NMS><ApplicationPassword>
NMSPWD
<CCB-NMS><NMS><dba.dbusername>
NMS Database Admin Username
NMSSYSDBUSER
<CCB-NMS><NMS><dba.dbuserpassword>
NMS Database Admin Password
NMSSYSDBPWD
<CCB-NMS><NMS><dbusername>
NMS Database username
NMSDBUSER
<CCB-NMS><NMS><dbuserpassword>
NMS Database User password
NMSDBPWD
<CCB-NMS><NMS><dbhostname>
NMS Application DB hostname
NMS_HOST.yourdomain.com
<CCB-NMS><NMS><dbportnumber>
NMS Application DB portnumber
NMS_DB_PORT_NO
<CCB-NMS><NMS><dbsid>
NMS Application DB system ID
NMS11GR2DB02
<CCB-NMS><NMS><policy>
The security policy that NMS accepts when invoking it’s webservice.
<CCB-NMS><NMS><GenericService><Protocol>
The protocol on which the NMS application is accessible.
http or https
<CCB-NMS><NMS><GenericService><Host>
The host name of NMS server application.
<CCB-NMS><NMS><GenericService><Port>
The port number of NMS application.
NMS Port
<CCB-NMS><NMS><GenericService><ContextRoot>
The context root of the NMS application.
nms-ms
Workflow Notification Properties
<CCB-NMS><WorkFlow.Notification>
<from.emailid>
Email ID which should be set in the “From” property of Workflow Notification bean.
Admin.user@yourdomain.com
<CCB-NMS><WorkFlow.Notification><mode>
Type of notification mode
EMAIL
SOA Admin Server
<SOA><AdminServer><hostname>
Host name of the server where admin server hosting SOA suite is installed.
adminserver.example.oracle.com
<SOA><AdminServer><portnumber>
Port number the admin server (hosting SOA suite) is listening to.
7001
<SOA><AdminServer><servername>
Admin server name (hosting SOA suite)
Admin Server
<SOA><AdminServer><username>
User name used to log in as an Admin server (hosting SOA suite) administrator.
weblogic
<SOA><AdminServer><password>
Password used to log in as an Admin server (hosting SOA suite) administrator.
xxxxxx
<SOA><AdminServer><domainname>
WebLogic domain name hosting SOA suite.
soa_domain
SOA Managed Server
<SOA><ManagedServer><hostname>
Host name of the server where managed server (hosting SOA suite) is installed.
managedserver.example.oracle.com
<SOA><ManagedServer><portnumber>
Port number the managed server (hosting SOA suite) is listening to.
8001
<SOA><ManagedServer><servername>
Managed server name (hosting SOA suite)
Managedserver1
<SOA><ManagedServer><username>
User name used to log in to managed server (hosting SOA suite) as an administrator.
weblogic
<SOA><ManagedServer><password>
Password used to log in to managed server (hosting SOA suite) as an administrator.
xxxx
Oracle HTTP Server Information
In a non-cluster environment these properties would be same as <ManagedServer> values.
<SOA><OHS><hostname>
The host name of the Oracle HTTP Server.
Oracle http server where cluster is managed.
<SOA><OHS><portnumber>
The port number of the Oracle HTTP Server.
Example: 7777
<SOA><OHS><servernames>
The list of server names that are defined as Managed Servers/Clusters.
In multiple managed servers, provide comma separated values.
Example: soa_server1, soa_server2
<SOA><OHS><Protocol>
http
MDS DB Information
<SOA><mdsconfig><mdsdbusername>
User name used to login to MDS schema.
XXX_MDS
<SOA><mdsconfig><mdsdbuserpassword>
Password used to log in to MDS schema.
<SOA><mdsconfig><mdsdbhostname>
Host name of the server hosting the database containing MDS schema.
Db.hostname.oracle.com
<SOA><mdsconfig><mdsdbportnumber>
Port number of the database containing MDS schema.
1521
<SOA><mdsconfig><mdsdbsid>
SID of the database containing MDS schema.
SID
JMS Information
<SOA><JMS><serverName>
The JMS server name.
Default:: CCBNMSFJS
Do not change.
<SOA><JMS><ModuleName>
The JMS module name.
Default:: CCBNMSFJM
<SOA><JMS><SubDeploymentName>
The Subdeployment name.
Default: CCBNMSFileSubDeployment
Do not change.
<JMSServerTarget>
The SOA Managed Server Target for JMS server.
soa_server1
For cluster environment, give only one managed server name under the cluster
<JMSModuleTargets>
The JMS Module targeted SOA managed servers/Clusters.
soa_cluster
For cluster environment give comma separated managed server names under the cluster or multiple cluster names
<SOA><JMS><PersitentStoreName>
The file store persistence details.
Default: CCBNMSFileStore
<SOA><JMS><PersitentStoreType>
JMS persistent store type (FileStores or DBStore).
Deployment script supports a file
Default: FileStores
<SOA><JMS><PersistentStoreFilename>
Directory path name where the file based persistent store should be created.
/opt/SOA14c/Product_Homes/CCB-NMS
<SOA><JMS><JMSCFName>
The file name of the ConnectionFactory.
CCBNMSCF
<SOA><JMS><JMSCFJNDI>
The JNDI file name of the ConnectionFactory.
jms/CCB-NMS/CCBNMSCF
Email Information
<SOA><EMAIL><MailAccessProtocol>
The protocol of the Mail Access.
IMAP
<SOA><EMAIL>
<OutgoingDefaultFromAddr>
The email address from which the outgoing mails are sent.
mail.id@yourdomain.com
<SOA><EMAIL><OutgoingMailServer>
The mail server name from where the mails are sent.
host.yourdomain.com
<SOA><EMAIL><OutgoingMailServerPort>
The port number of the outgoing mail server.
465
<SOA><EMAIL>
<OutgoingMailServerSecurity>
The security for the outgoing mail server.
SSL
<SOA><EMAIL><OutgoingUsername>
The user name of the outgoing email.
mail.id@ yourdomain.com
<SOA><EMAIL><Outgoingpassword>
The password of the outgoing email.
Your password
<SOA><EMAIL><IncomingMailServer>
The mail server name where mail is received.
host.yourdomain.com
<SOA><EMAIL><IncomingUserIDs>
Incoming user IDs.
<SOA><EMAIL><IncomingUserPasswords>
Incoming passwords.
Your password
<SOA><EMAIL><applicationName>
The application for which the UMS configuration is considered.
CCBNMS
<SOA><EMAIL><capability>
Sets the driver's capability to send or receive messages.
For 14c, the values are SEND, RECEIVE, and BOTH.
Error Handling Database Information
<EH><dba.dbusername>
User name used to log in as a database administrator (DBA). This database hosts the schema required for the integration.
system
<EH><dba.dbuserpassword>
Password used to log in as a database administrator (DBA). This database hosts the schema required for the integration.
xxxxxx
<EH><dbusername>
User name to log in to the error handling schema for the integration. This User can be automatically created by the install (set dbuser.createflag to true) or manually outside the install process.
CCBNMSUSER
<EH>dbuserpassword>
Password to log in to the error handling schema for the integration.
xxxxxx
<EH><dbuser.createflag>
If set to true, the db user can be automatically created by the install.
If this value is set to false, the schema needed for integration error handling will not be automatically created by the install and will need to be created manually prior to running the installation. When creating the user manually, grant connect and resource to the user.
true
<EH><dbhostname>
The DB Hostname of the error handling schema for the integration.
host.yourdomain.com
<EH><dbportnumber>
The DB Port of the error handling schema for the integration.
1521
<EH><dbsid>
The DB SID of the error handling schema for the integration.
INTFMWPD
