Activity Type | Completion Events | Required | Algorithm | Description |
Install Meter | Install Device Completion Event | Yes | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised |
D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised | |||
D1-VALCERD | Validates that the Reading Date Time is provided and at least one entry exists in the Reading Detail List for either the New Device or Existing Device | |||
Install Meter | Create FA IMD Completion Event | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised |
Update SP - Field Work Completion | No | D1-VALCESPD | Validates that the Service Point ID and at least one of the following fields has been provided: Service Point Warning, Service Point Instructions, or Service Point Instruction Details | |
Update Device - Field Work Completion | No | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised | |
D1-UPDDVCCI (executed) | checks that the badge number / device ID combination in the completion information matches the device data recorded in the system. If there is a discrepancy, the algorithm throws an error | |||
Connect Meter - Field Work Completion | No | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. | |
D1-VALCERD | Validates that the Reading Date Time is provided and at least one entry exists in the Reading Detail List for either the New Device or Existing Device. | |||
Read Meter | Create FA IMD Completion Event | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
Update SP - Field Work Completion | No | D1-VALCESPD | Validates that the Service Point ID and at least one of the following fields has been provided: Service Point Warning, Service Point Instructions, or Service Point Instruction Details. | |
Update Device - Field Work Completion | No | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised. | |
D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. | |||
D1-UPDDVCCI (executed) | checks that the badge number / device ID combination in the completion information matches the device data recorded in the system. If there is a discrepancy, the algorithm throws an error. | |||
Exchange Meter | Remove Device - Field Work Completion | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
Install Device - Field Work Completion | Yes | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised. | |
Exchange Meter | Install Device - Field Work Completion | Yes | D1-VALCERD | Validates that the Reading Date Time is provided and at least one entry exists in the Reading Detail List for either the New Device or Existing Device. |
Create FA IMD Completion Event | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. | |
D1-UPDDVCCI (executed) | Checks that the badge number / device ID combination in the completion information matches the device data recorded in the system. If there is a discrepancy, the algorithm throws an error. | |||
Item - Connect SP at Device | Connect SP - Field Work Completion | Yes | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised. |
Update Item - Field Work Completion | No | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised. | |
Item - Connect SP at Device | Update Item - Field Work Completion | No | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
D1-VALCEDUPD | Validates existing and new badge number, manufacturer, model. | |||
Disconnect SP at Meter and Remove Meter | Disconnect SP at Device-Field Comp | Yes | D1-VALCESPDL | Validates that the Service Point ID and Disconnect Location have both been provided. If not an error will be raised. |
Remove Device - Field Work Completion | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. | |
Disconnect SP at Meter and Remove Meter | Update Device - Field Work Completion | No | D1-UPDDVCCI (executed) | Checks that the badge number / device ID combination in the completion information matches the device data recorded in the system. If there is a discrepancy, the algorithm throws an error. |
Disconnect SP at Device and Remove Device | Disconnect SP at Device-Field Comp | Yes | D1-VALCESPDL | Validates that the Service Point ID and Disconnect Location have both been provided. If not an error will be raised. |
Remove Item - Field Work Completion | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. | |
Item - Exchange Device | Remove Item - Field Work Completion | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
Item - Exchange Device | Install Item - Field Work Completion | Yes | D1-VALCESP | Validates that a Service Point ID has been provided in the completion details, if not an error is raised. |
Trim Tee | Pass-Through Field Completion Results | D1-VALFACI | Validates the Field Activity Completion Information is populated. | |
Service Investigation | Update SP - Field Work Completion | No | D1-VALCESPD | Validates that the Service Point ID and at least one of the following fields has been provided: Service Point Warning, Service Point Instructions, or Service Point Instruction Details. |
Turn on Pilot Light | Pass-Through Field Completion Results | Yes | D1-VALFACI | Validates the Field Activity Completion Information is populated. |
Meter Test | Create FA IMD Completion Event | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
D1-UPDDVCCI (executed) | Checks that the Badge Number/Device ID combination in the completion information matches the device data recorded in the system. If there is a discrepancy, the algorithm throws an error. | |||
Meter Inspect | Create FA IMD Completion Event | Yes | D1-VALCEDVC | Ensures that either a Device ID is populated in either the new or existing Device portions of the Completion Event schema. If no Device ID is found an error is raised. |
All | Create Attachments | No | D1-RETFACTV | Retrieve Field Activity from inbound Communication |
D1-VALCEACD | Validate Completion Event Attachment Creation Data |
