Taking the Backup of an Existing Package
Before importing the new package, you must take the backup of an existing package which has all your customizations.
To take a backup of an existing package:
1. Login to Oracle Integration cloud.
2. Navigate to Integrations > Package.
3. Search for the “ccb_ofsc” package.
4. Click the
![](../CCS-OFS_CONFIGURATION_GUIDE_22A/images/C2M-OFSC_Import-Configure-Test_Connections.05.2.1.jpg)
icon and select
Export. The selected package will be downloaded to your local machine.
To take a backup of existing lookups:
2. Navigate to Integrations > Lookups.
3. Search for the “SOMOFSC” lookups.
4. Click the
![](../CCS-OFS_CONFIGURATION_GUIDE_22A/images/C2M-OFSC_Import-Configure-Test_Connections.05.2.2.jpg)
icon and select
Export to CSV. The selected lookup file will be downloaded to your local machine in .CSV format.
