Removing Old References
After creating a backup of the required items, remove all references to lookups and libraries that are related to the older/previous version. Make sure to perform this step accurately since merging the changes from one version to other version for lookups and libraries is not taken care in the upgrade process.
Deleting References to Lookups
To remove references to lookups related to the older version of integration:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Lookups.
3. Select all lookups related to the integration.
4. From the Options menu, click Delete to delete the selected lookups.
For a list of lookups in the integration, refer to the
Lookups section in
Chapter 3:
Validations.
Important! The current integration version might not include the same list of lookups as the previous integration version. A few of them might be included or deprecated. Please refer to the specific integration version documentation that you are running to get the list of lookups.
Deleting References to Libraries
To remove the references to libraries related to the older version of integration:
2. Navigate to Integrations > Libraries.
3. Select all libraries related to the integration.
4. From the Options menu, click Delete to delete the selected libraries.
For a list of libraries in the integration, refer to the
Libraries section in
Chapter 3:
Validations.
Important! The current integration version might not include the same list of libraries as the previous integration version. A few of them might be included or deprecated. Please refer to the specific integration version documentation that you are running to get the list of libraries.
