Lookup Name | Integration Name | Purpose |
OUTL-BRT-NOTIFHUB_ DeliveryChannel | Oracle Utilities OCI Stream Responsys Notif Send | Maps CCB Delivery Type to the Integration-defined delivery type of “sms” or “email”. |
OUTL- BRT-NOTIFHUB_ DeliveryInstance | Oracle Utilities OCI Stream Responsys Notif Send | Maps the Integration-defined Oracle Responsys delivery instance ID to the actual Oracle Responsys identifier. The ResponsysId can be anything that identifies a Oracle Responsys instance. Example: Description, URL, Instance ID, etc. This Responsys ID is used in the error email notifications sent to identify the Oracle Responsys instance where the invocation failed. Note: The values in the Intg_DeliveryInstanceId should be RESP1,RESP2,RESP3. |
OUTL-BRT-NOTIFHUB_ DeliveryRouting | • Oracle Utilities OCI Stream Notif linkChannel • Oracle Utilities CCB OCI Stream Notif Upload | Maps CCB CIS Division to the Oracle Responsys delivery Instance to route the message. The three Oracle Responsys instance connections provided out of the box are identified as RESP1 , RESP2 and RESP3 in the DeliveryInstance column. Note: These values should not be renamed to a different name as these names are referenced as is in the OIC flow. |
OUTL-BRT- NOTIFHUB_ ConfigProps | • Oracle Utilities OCI Stream Responsys Notif Send • Oracle Utilities OCI Stream Notif linkChannel • Oracle Utilities CCB OCI Stream Notif Upload • Oracle Utilities NMS OCI Stream Notif Upload | Maps the PropertyName column to the respective Value column. Do not change the value in the PropertyName column. |
OUTL-BRT- NOTIFHUB_Email_ID | • Oracle Utilities OCI Stream Notif linkChannel • Oracle Utilities CCB OCI Stream Notif Upload • Oracle Utilities NMS OCI Stream Notif Upload • Oracle Utilities OCI Stream Responsys Notif Send | Maps the “from” and “to” recipient values to the mentioned email IDs. Configure multiple emails using a comma to separate the email IDs. |
OUTL-BRT- NOTIFHUB_NMS_CCB_NotifTypes | Maps the CCB Notification Types to the NMS Trigger Code and Planned/Unplanned Flag values. The DVM column, TriggerCode_Planned is combination of two parts. The first part is a number which represents NMS trigger code and the second is the planned or unplanned flag Y or N. “N” means unplanned outage and “Y” mean Planned outages. For example: “1N” means Unplanned outage started and “4N” means Unplanned outage cancelled. The flags are case sensitive and must be in uppercase. The following are the NMS trigger codes and can be combined with Planned or Unplanned outages flags: 1 - Outage started 2 - Outage restored 3 - Outage scheduled 4 - Outage scheduled 5 - Outage updated ERT Note: “Unplanned outage schedule (3N) is not supported”. |
