Property Name | Sample Value | Description | Used in Integration Process Name |
nms.datafield.propertylist | OUTAGETIME,CUSTOMERSOUT,CAUSE, ESTRESTTIME, CREWETA, COMPLETIONTIME | Oracle Utilities NMS OCI Stream Notif Upload | |
email.flag | True | If this value is set to true, an email notification will be sent out. Valid values: true/false Default: true | • Oracle Utilities OCI Stream Responsys Notif Send • Oracle Utilities NMS OCI Stream Notif Upload • Oracle Utilities OCI Stream Notif linkChannel • Oracle Utilities OCI Stream Notif Upload |
resp.email.permission | OPTOUT | Merges the rule corresponding to “defaultPermissionStatus” field in Oracle Responsys API. Do not change. | Oracle Utilities OCI Stream Responsys Notif Send |
resp.reject.channel.empty | E,M | Merges the rule corresponding to “rejectRecordIfChannel Emtpy”field in Oracle Responsys. Do not change. | Oracle Utilities OCI Stream Responsys Notif Send |
resp.optout.value | O | Merges the rule corresponding to “optoutValue” field in Oracle Responsys. | Oracle Utilities OCI Stream Responsys Notif Send |
resp.optin.value | I | Merges the rule corresponding to “optinValue”field in Oracle Responsys. | Oracle Utilities OCI Stream Responsys Notif Send |
resp.update.on.match | REPLACE_ALL | Merges the rule corresponding to “updateOnMatch” field in Oracle Responsys. Controls how the existing record should be updated. | Oracle Utilities OCI Stream Responsys Notif Send |
resp.match.operator | NONE | Merges the rule corresponding to “matchOperator” field in Oracle Responsys. Operator to join the match column names. | Oracle Utilities OCI Stream Responsys Notif Send |
