Importing the Oracle Integration Cloud Package from Oracle Cloud Marketplace
All integration points are shipped as part of single package (outl.ba.notifications_hub.1.22.1000.par) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Browse through the list of applications and select the pre-built integration package to import.
Alternatively, you can search for “Oracle Utilities” and select the Notifications Hub integration option.
4. Click GetApp.
5. Review and accept the “Oracle Standard Terms and Restrictions”.
6. Click Next. The My Oracle Support portal opens.
7. Download the integration package from My Oracle Support.
8. When prompted, select the server where the pre-built integration file should be uploaded.
The pre-built integration is imported as a package file (.par) that is visible on the Packages page in Oracle Integration Cloud.
9. On the Integrations page, the individual integrations of the imported package file that are designated with a BUILT BY ORACLE message are displayed.
To import a package in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Designer > Packages.
3. Click Import.
4. Select the .par file downloaded from Oracle Cloud Marketplace.
5. Verify if the package is imported is successfully.
