OCI Target Notification Stream | "Responsys //rest/api/v1.3/campaigns/{notifcationTemplate}/sms //rest/api/v1.3/campaigns/{notifcationTemplate}/email " | DVM | Comments | ||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | ||
messageId | Field | Not Mapped | |||||
origin | Field | Not Mapped | |||||
accountId | Field | optionalData/value (optionalData/key = INT_ACCOUNT_ID') | mergeTriggerRecordData/mergeTriggerRecords | ||||
notificationType | Field | optionalData/value (optionalData/key = INT_NOTIFTYPE') | mergeTriggerRecordData/mergeTriggerRecords | ||||
cisDivision | mergeTriggerRecordData/mergeTriggerRecords | Not Mapped | |||||
contactId | optionalData/value (optionalData/key = INT_CONTACT_ID') | mergeTriggerRecordData/mergeTriggerRecords | |||||
personId | optionalData/value (optionalData/key = INT_PERSON_ID') | mergeTriggerRecordData/mergeTriggerRecords | |||||
language | mergeTriggerRecordData/mergeTriggerRecords | ||||||
firstName | optionalData/value (optionalData/key = INT_FIRST_NAME') | mergeTriggerRecordData/mergeTriggerRecords | |||||
lastName | optionalData/value (optionalData/key = 'INT_LAST_NAME') | mergeTriggerRecordData/mergeTriggerRecords | |||||
deliveryChannel | OUTL-BRT-NOTIFHUB_ DeliveryChannel | This lookup is used to determine if the SMS or Email campaign API needs to be invoked. | |||||
deliveryValue | fieldValues | mergeTriggerRecordData/mergeTriggerRecords | |||||
notificationTemplate | This value is used to populate the campaign name in the API URL. | ||||||
deliveryInstance | This value is used to determine the Responsys instance to invoke. RESP1,RESP2,RESP3 correspond to three Responsys instance connections that is provided out of the box. | ||||||
fieldValues | mergeTriggerRecordData/mergeTriggerRecords | Mapped to fieldName CUSTOMER_ID as contactination of accountId | personId. | |||||
fieldNames | mergeTriggerRecordData | Multiple fieldNames nodes with each mapped as following EMAIL_ADDRESS_ if the campaign type is email MOBILE_NUMBER_ if the campaign type is sms CUSTOMER_ID_ | |||||
data | List | ||||||
key | data | Field | optionalData/key | ||||
value | data | Field | optionalData/value | ||||
matchColumnName1 | mergeTriggerRecordData/mergeRule | EMAIL_ADDRESS_ for Email MOBILE_NUMBER_ for SMS. These values are hardcoded in the flow. | |||||
matchColumnName2 | mergeTriggerRecordData/mergeRule | null | |||||
insertOnNoMatch | mergeTriggerRecordData/mergeRule | True. Same for Email and SMS. | |||||
defaultPermissionStatus | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | This is the same value sent for Email and SMS. Property name: resp.email.permission | ||||
rejectRecordIfChannelEmpty | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Property name: resp.reject.channel.empty | ||||
optoutValue | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Metadata value to indicate optoutValue. Property name: resp.optout.value. | ||||
optinValue | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Metadata value to indicate optinValue. Property name: resp.optin.value | ||||
updateOnMatch | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Property name: resp.update.on.match | ||||
htmlValue | mergeTriggerRecordData/mergeRule | “H” Same for both Email and SMS | |||||
textValue | mergeTriggerRecordData/mergeRule | “T” value is passed | |||||
matchOperator | mergeTriggerRecordData/mergeRule | OUTL-BRT-NOTIFHUB_ConfigProps | Same for both SMS and Email. Property name: resp.match.operator |
