Supported Applications
The supported application versions in this integration are:
• Oracle Utilities Customer to Meter - V2.9.0.0.0 or higher
• Oracle Utilities Customer Cloud Service - 22A or higher
• Oracle Integration Cloud - V22.1.3.0.0 or higher
• Oracle Utilities Network Management System - V2.5.0.1.7 or higher
• Oracle Responsys - 22A or higher
• OCI Streaming
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
