Creating Profile List and Zero Record Filter
The default profile list will determine where customer records, also referred to as profiles, will be stored.
To create a profile list and a zero record filter:
1. Create a profile list with the default schema. Navigate to Profile Lists and click Create New List.
2. Select the appropriate name from the
Brand drop-down menu and
CM_OU_Campaign from the
Folder drop-down menu.
![Create list window where the user can define the name and location of the list. This window shows the Name, Brand, Folder, and Description text fields to be populated by the user. Create list window where the user can define the name and location of the list. This window shows the Name, Brand, Folder, and Description text fields to be populated by the user.](../NH_SETUP_GUIDE_22A/images/select-brand-and-folder-1chap3.png)
3. Create a zero record filter. From the
Create Filter drop-down menu select
Profile data.
![Campaign page. The Create Filter drop-down menu is located within the Filters tab, on the extreme right of the row immediatly above the table of results. Campaign page. The Create Filter drop-down menu is located within the Filters tab, on the extreme right of the row immediatly above the table of results.](../NH_SETUP_GUIDE_22A/images/customizing2-create-filter-and-profile-data.png)
4. Populate the fields in the
Profile attributes section. Enter the condition “
RIID_ is equal to 1” (as shown below) and click
Save to update the data in the
CM_OU_Campaigns folder.
![Profile Data page showing the Profile navigation pane to the left, and the profile attributes section in the middle. The Save button is located on the upper right corner. Profile Data page showing the Profile navigation pane to the left, and the profile attributes section in the middle. The Save button is located on the upper right corner.](../NH_SETUP_GUIDE_22A/images/customizing1-enter-condition.png)
5. The
Profile List and
Zero Record folder will be shown as below.
![Campaign page showing the list of folders within the Filters tab. Campaign page showing the list of folders within the Filters tab.](../NH_SETUP_GUIDE_22A/images/profile-list-and-zero-record-folder-4chap3.png)
6. Delete the filters that are not necessary for the functionality.
