Updating the Email Campaigns
To update an email campaign:
1. Update the following entities for each email campaign:
• Profile List
• Selected filters
• From and To addresses
2. Select the appropriate CM folder and profile list (created through the steps in the Creating New Folders section) from their corresponding drop-downs to populate the corresponding fields in the About your campaign section.
3. Update the selected filters to the Zero Record Filter that you created.
4. Update the From: and To: addresses.
5. After you successfully complete the steps, Oracle Responsys will prompt you (via error notifications) to correct the following sections of the campaign:
a. Click Show errors next to the Preview and Test drop-down menu.
b. Click the error.
![Validation errors prompt showing two messages with a warning icon. Validation errors prompt showing two messages with a warning icon.](../NH_SETUP_GUIDE_22A/images/click-on-the-error-9chap3.png)
c. Update
Reply to: and
From: addresses. Select the applicable options from the respective drop-down menus.
![Message Header window showing the Reply to and From address drop-down menus. Message Header window showing the Reply to and From address drop-down menus.](../NH_SETUP_GUIDE_22A/images/update-addresses-10chap3.png)
