Sync Mobile Control Data Information from WACS to OFS
Information from Oracle Utilities Work and Asset Cloud Service has to be replicated to Oracle Field Service to provide the drop-down information used in the Oracle Field Service mobile application. Create work skills, work skill properties, and work skill conditions in Oracle Field Service to match activities with resources and for crew tracking.
As part of this accelerator, Oracle Utilities WACS OFS Admin Data Sync deployed on Oracle Integration Cloud (OIC) is provided to create these configurations automatically making migration of data easier and get rid of tedious manual work.
Oracle Utilities WACS OFS Admin Data Sync needs to be run on initial installation or on a need to basis when new control data from Oracle Utilities Work and Asset Cloud Service or work skill related configurations needs to be created or updated in Oracle Field Service.
This sync integration process is manually run in Oracle Integration for Cloud by scheduling the integration process to run on a scheduled date or selecting Submit Now from the menu of the activated sync integration process to initiate an instance of the integration. An optional language parameter can be entered, it should be an ISO 2 letter language code, to determine the description to retrieve from Oracle Utilities Work and Asset Cloud Service and in what language code the property name should be created in Oracle Field Service Cloud. If the language is not populated or blank, it is defaulted to English (en).
Refer to the Business Flows chapter in Oracle Utilities Work and Asset Management Integration to Oracle Field Service Configuration Guide at
https://docs.oracle.com/en/industries/utilities/integrations-index.html.
The following configurations are created or updated by the Sync Process:
• Create or update the enumeration values for the Oracle Field Service properties.
To verify the information that is synchronized from Oracle Utilities Work and Asset Cloud Service to Oracle Field Service, navigate to the respective property and check the enumeration values. Click Modify.
Note: After a resource is created in Oracle Utilities Work and Asset Cloud Service, the resource code (craft code, equipment code and other resource code) cannot be changed. The sync integration process uses these resource codes to create the enumeration values for equipment type, craft and other resource type property in Oracle Field Service Cloud. Slash (/) should not be included in the resource code and special characters like &,>, and < should not be included in Craft code
Note: The sync integration process cannot delete enumeration values added to a property in Oracle Field Service Cloud; the OFSC REST API that updates the enumeration values of a property does not allow it. The only way to delete an enumeration value(s) in a property is by deleting the property, recreate the property and run the sync to get the latest values.
• Work Skill related configurations
1. A work skill is created in Oracle Field Service for each craft synchronized from Oracle Utilities Work and Asset Cloud Service. Work skill is a job-specific skill and is used as a criteria to match activities with the resources. The label format for Work Skill created in Oracle Field Service is:
• W_ + WACS craftcode
Example: Work Skill created in Oracle Field Service
![This is an example of the Edit window for a work skill called Carpenter. The user must provide a name, a label, a mode for sharing, and select the Active checkbox. This is an example of the Edit window for a work skill called Carpenter. The user must provide a name, a label, a mode for sharing, and select the Active checkbox.](../WACS-OFS_SETUP_GUIDE_22A/images/additionalOFS-work-skill-example-image1.png)
2. A work skill property on the activity level is created in Oracle Field Service for each craft synced from Oracle Utilities Work and Asset Cloud Service. This property will contain information about how many people with the particular work skill is needed for the activity. The label format for Work Skill property created in Oracle Field Service is:
• W_ + WAM craftcode + _Nd
Example: Work Skill Property created in OFSC
![Modify Property section where the user is to provide the new name and label to modify the work skill property. Modify Property section where the user is to provide the new name and label to modify the work skill property.](../WACS-OFS_SETUP_GUIDE_22A/images/additionalOFS-work-skill-modify-property-image2.png)
3. Work Skill Conditions are created in Oracle Field Service based on the craft and the configuration property value of workSkillCond.actvtySameSkillMaxWorker.default obtained from WAMOFSC_ConfigProps lookup defined in Oracle Integration Cloud. This configuration property value contains the maximum number of people with the same work skill allowed to work simultaneously in an activity.
In this example: For work skill = Carpenter and workSkillCond.actvtySameSkillMaxWorker.default = 3, these are the work skill conditions created.
Example: Work Skill Conditions created for Work Skill Carpenter in Oracle Field Service
![Work Skill Conditions page showing the work skill conditions in a table that presents their ID, Name, Status, and possible Actions. Work Skill Conditions page showing the work skill conditions in a table that presents their ID, Name, Status, and possible Actions.](../WACS-OFS_SETUP_GUIDE_22A/images/additionalOFS-work-skill-conditions-page-image4.png)
These configurations are used to track teams (crews) consisting of people with different work skills and make sure that activities that require several people simultaneously is assigned to the right team.
