Properties
Properties enable the integration specific UIs create and map the Oracle Field Service UI element with a property. Each property is classified into types such as field, integer, enumeration, string on the basis of requirements and should be addressed using this property.
To import the property file included in the accelerator package:
1. On the Configuration page, select Resources, Activities, Inventories > Properties.
2. Click Import.
3. Browse to the location of the file to be imported and click Import.
4. Verify the successful import of the file. The Successfully Imported message with number of properties imported is displayed. Make sure the Imported with warnings and Not imported count is 0.
