Testing the Integration Flows
The following table lists the end point URLs for respective applications in which these endpoints need to be configured. Configure the same and perform an end-to-end testing.
Integration Name
End Point URL to be Configured
Application to be Configured
Oracle Utilities CCS OFSC Activity Process
https://hostname:port/ic/ws/integration/v1/
flows/oracleutilities/
OUTL-BA-CCS_OFSC_ACTIVITY_PROCES/1.0/
C2M/CCS
Oracle Utilities OFSC CCS Activity Create
https://hostname:port/ic/api/integration/v1/flows/ofsccloudadapter/OUTL-BA-OFSC_CCS_ACTIVITY_CREATE/1.0/notify
As OFSC is event based, there is no need to configure the integration endpoint URLs. Subscription for the event will be created once the respective integration is activated.
Oracle Utilities OFSC CCS Activity Complete
https://hostname:port/ic/api/integration/v1/flows/ofsccloudadapter/OUTL-BA-OFSC_CCS_ACTIVITY_COMP/1.0/notify
Oracle Utilities CCS OFSC Appointment Get
https://hostname:port/ic/ws/integration/v1/flows/oracleutilities/OUTL-BA-CCS_OFSC_APPMT_GET/1.0/
C2M/CCS
Oracle Utilities CCS OFSC Activity Get Status
https://hostname:port/ic/ws/integration/v1/flows/oracleutilities/OUTL-BA-CCS_OFSC_ACTIVITY_STATUS/1.0/
C2M/CCS
Oracle Utilities OFSC CCS Device Verification
https://hostname:port/ic/api/integration/v1/flows/rest/OUTL-BA-CCS_OFSC_DEVICE_VERIFY/1.0/
OFSC
Oracle Utilities CCS OFSC Admin Sync
https://hostname:port/ic/api/integration/v1/integrations/OUTL-BA-CCS_OFSC_ADMIN_SYNC/
NA
Oracle Utilities OFSC CCS ServicePoint Query
https://hostname:port/ic/api/integration/v1/flows/rest/OUTL-BA-CCS_OFSC_SP_QUERY/1.0/
OFSC
