Migrating from OIC Test Environment to Production
Make sure all Oracle Integration Cloud artifacts are imported successfully.
To import the customizations added in the test environment to production:
1. Export the ccs_ofsc_fieldwork_custom_22B package from the test environment and import it into the production environment.
Note: For information about upgrading an older version of integration to 22B, please refer to the Oracle Utilities Customer Cloud Service Integration to Oracle Field Service Upgrade Guide 22B included in this release. The documentation is available on Oracle Help Center at:
2. Configure all your connections.
3. Activate the base integrations and customized integrations, and configure the respective end point URL into the Oracle Utilities Customer Cloud Service Message Sender.
4. Deactivate the base integrations for which a cloned, customized integration copies were created.
