Applications
This element is used to create an application to communicate with Oracle Utilities Customer Cloud Service through Oracle Integration Cloud. Various application types can be chosen, but since Oracle Utilities Customer Cloud Service integration to Oracle Field Service is through Oracle Integration Cloud, it is used as the application type.
To configure an outbound channel:
1. Navigate to the Configuration page and click the Applications icon.
2. Click
Add Application. Enter the required details and click
OK.
![Add channel window. The Ok button is located on the bottom right corner. Add channel window. The Ok button is located on the bottom right corner.](../CCS-OFS_SETUP_GUIDE_22B/images/additional-ofs-11-add-channel.png)
