Device Data Sync
The following device information will be synced in Oracle Field Service when the Admin Sync flow runs successfully. Hence, there is no need to add the data to the Oracle Field Service properties manually.
Device Manufacturer
Device Model
Device Configuration Type
Device Types
Device Head End System
Device Manufacturer
The following Oracle Field Service properties will sync with device manufacturer data created in Oracle Utilities Customer Cloud Service.
Property Description
Property Label
New Item Manufacturer
c2m_newitem_manufacturer
Existing Item Manufacturer
c2m_item_manufacturer
New Meter Manufacturer
c2m_newmeter_manufacturer
Existing Meter Manufacturer
c2m_meter1_mfg
Device Model
The following Oracle Field Service properties will sync with device model data created in Oracle Utilities Customer Cloud Service.
Property Label
New Meter Model
c2m_newmeter_model
Existing Meter Model
c2m_meter1_model
New Item Model
c2m_newitem_model
Existing Item Model
c2m_item_model
The following Oracle Field Service properties will sync with device configuration data created in Oracle Utilities Customer Cloud Service.
Property Label
New Meter Configuration Type
c2m_new_meter_type
Existing Meter Configuration Type
c2m_meter1_type
New Item Configuration Type
c2m_new_item_type
Existing Item Configuration Type
c2m_item_type
Device Types
The following Oracle Field Service properties will sync with device types data created in Oracle Utilities Customer Cloud Service.
Property Label
New Meter Device Type
c2m_newmeter_devicetype
Existing Meter Device Type
c2m_deviceType
New Item Device Type
c2m_newitem_deviceType
Existing Item Device Type
c2m_item_device_type
The following Oracle Field Service properties will sync with device head end system data created in Oracle Utilities Customer Cloud Service.
Property Label
New Meter Head End System
c2m_newmeter_headend
Existing Meter Head End System
c2m_headendSystem
Customizations
To add new elements related to device data, such as manufacturer, model, configuration type, device types or head end system:
1. Create the property in Oracle Field Service.
2. Configure the property count in SOMOFSC_ConfigProps lookup.
Below are the configuration properties to be modified as part of the Device Data sync.
Property Name
Default Value
Comments
som.adminsync.configurationtype.properties.count
4
Change the value if you want to add new property for configuration type
som.adminsync.manufacturer.properties.count
4
Change the value if you want to add new property for manufacturer
som.adminsync.model.properties.count
4
Change the value if you want to add new property for model
som.adminsync.devicetypes.properties.count
4
Change the value if you want to add new property for device types
som.adminsync.headendsystem.properties.count
2
Change the value if you want to add new property for head end system
Config Props page.
3. Once the value of the configuration properties are changed based on the requirement, add the property label in the lookup based on the property that belongs to manufacturer, model or configuration type.
4. Add the property label to the lookup if the property belongs to Configuration type.Device Configuration Data page.
5. Add the property label to the lookup if the property belongs to manufacturer.Device Manufacturer Data page.
6. Add the property label to the lookup if the property belongs to model.DeviceModelData page.
7. Add the property label to the below lookup if the property belongs to device types.Device Types Data page.
8. Add the property to the below lookup if the property belongs to head end system.Device Head End System Data page.
