Activity Type Name | Activity Type Label |
Turn on Pilot light | Turn on Pilot light |
Service Investigation | Service Investigation |
Trim Tree | Trim Tree |
Disconnect SP at Device and Remove Device (Item) | Disc SP Dev Rem Dev |
Item Exchange | Item Exchange |
Connect SP at Item | Connect SP at Item |
Exchange Meter | Meter Exchange |
Read Meter | Meter Read |
Disconnect SP at Meter and Remove Meter | Disc SP Met Rem Met |
Install Meter | Meter Install |
Disconnect Warning | Disconnect Warning |
Inspect Meter | Meter Inspect |
Test Meter | Meter Test |
Disconnect SP from Item and Remove Item | |
Connect SP to Item |
