Managing Catalog Services
The web service catalog is used by Oracle Integration Cloud to communicate with the respective application. It is used to identify services that should be retrieved by the Oracle Utilities Adapter. It is configured in Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog in Oracle Utilities Work and Asset Cloud Service:
1. Login to Oracle Utilities Work and Asset Cloud Service.
2. Navigate to Admin menu > [W or Integration] > Web Service Catalog page. Alternatively, you can find the page from the Search menu.
3. Select REST Web Service Class.
4. Add the REST inbound web services mentioned below to the catalog.
