Property Name | Sample Value | Description |
email.flag | true | If this value is set to true, email notification will be sent out. Valid values: true/false. Default to true. |
wacs.externalsystem | HCM | External System defined in WACS for Oracle HCM Cloud Application |
maxerrorcount.per.emailnotification | 100 | This value controls the number of errors to be sent out in an error email notification. When the error count reaches this value, an error email notification is sent out. It will keep sending an email notification for every interval of the maximum error count. Example: There are 150 records to be processed and this property is set to 50. When the process reached it's 50th error record then an email notification listing the 50 error records is sent. For every 50 error records an email notification is sent out. |
wacs.inc.newempstatus | ACTIVE | Defines newly hired employee status. It should be the same value defined in OUTL-BRT-HCM_WACS_EmployeeStatus lookup /wacs column. |
wacs.inc.empphonetype | W1PR | Defines the employee primary phone type in WAM for Newhire incremental sync. |
hcm.inc.salaryannualrate | 2080 | Defines employee salary annual rate during employee assignment incremental sync. This should be the same value defined as profile value when submitting employee bulk data extract. |
wacs.inc.termempstatus | INACTIVE | Defines terminated employee status which is INACTIVE; this should be the same value defined in OUTL-BRT-HCM_WACS_EmployeeStatus lookup /wacs column. |
wacs.offset | -08:00 | Defines the WACS offset. |
hcm.offset | +00:00 | Defines the HCM offset. |
