HCM Extract Absence Bulk File | WACS REST Service: W1-Leave (Operation: PUT, URI: /{externalId} ) | DVM Mapping | Comments | ||
Element Name | Parent Element | Type | |||
W1UpdLeave | Group | ||||
input | W1UpdLeave | Group | |||
externalSystem | input | Field | Defaulted by Integration. Get value from property name wacs.externalsystem in the ERPWACS_ConfigProps file. This value must exist in WAM. | ||
PERSON_ENTRY_ID | externalId | input | Field | This is the ERP's unique system generated Absence ID. | |
ABSENCE_TYPE | leaveType | input | Field | HCMWACS_AbsenceType | |
TYPE_REASON | description | input | Group | Absence Description is optional in WACS. If type reason is populated, use that as the description. If type reason is blank, use comments. If both type reason and comments are blank, no description is passsed. | |
COMMENTS | description | Absence Description is optional in WACS. If type reason is populated, use that as the description. If type reason is blank, use comments. If both type reason and comments are blank, no description is passsed. | |||
applicantId | input | Field | WAM Employee ID - Not Mapped | ||
PERSON_ID | applicantExternalId | input | HCM Employee ID. This external employee ID should exist in WACS. | ||
STATUS_CODE | status | input | Field | HCMWACS_AbsenceStatus | Absence Status. For initial load, HCM send Approved absences only. For incremental load, send Approved and Canceled absences only. Use DVM to translate the ERP status to the equivalent WAM values. *** WAM Statuses: Approved, Inactive and Canceled. ERP Status Code: SUBMITTED and ORA_WITHDRAWN. |
START_DATE_TIME | startDateTime | input | Field | Map START_DATE_TIME, convert it to xsd format and use the timezone from ABS_START_DATE. | |
END_DATE_TIME | endDateTime | input | Field | Map END_DATE_TIME, convert it to xsd format and use the timezone from ABS_END_DATE. | |
output | W1UpdLeave | Group | |||
leaveId | output | Field |
