Linking to Additional Oracle Responsys Instances
To link additional Oracle Responsys instances:
1. Clone the Oracle Utilities OCI Steam Responsys Notif integration. For steps to create a custom flow, refer to the Cloning an Integration section.
2. Click the newly created custom flow. This opens the flow in edit mode.
3. Clone Oracle Utilities REST Responsys for Notif Hubconnection. For steps, refer to the Cloning a Connection section.
4. Configure the connection details to point to the new Oracle Responsys instance.
5. Update the OUTL-BRT-NOTIFHUB_DeliveryRouting lookup to map the desired CIS Division to the new Oracle Responsys instance.
Example: “RESP4”.
6. Update OUTL-BRT-NOTIFHUB_DeliveryInstance to map this Oracle Responsys instance (RESP4) to Response ID value to represent the new Oracle Responsys instance. The value in the ResponsysId column is populated on the error notifications sent out for this Oracle Responsys instance.
7. Update the integration property values. Click the hamburger menu on the right and select Update Property Values.
8. Enter new value for responsysInstance that matches the value entered in OUTL-BRT-NOTIFHUB_DeliveryRouting and OUTL-BRT-NOTIFHUB_DeliveryInstance.
In this example: “RESP4”
9. Save and activate the custom flow.
