Creating Export Feed Data for Customer Contact
To create Export Feed Data job for Customer Contact functionality:
1. Create Export Feed Data job and select only the supported events.
2. Make sure the following are set in the Destination Specification tab:
• Field delimiter is “,” (comma)
• Insert column header as first line option is selected.
• In the Create file with record count field, file extension is set to “cnt”.
The job can be scheduled on an appropriate cadence based on your business needs. However, it is highly recommended that this job is configured to run frequently, which will result in smaller file sizes for each run, and optimal performance of the process (daily vs. weekly/monthly if applicable).
