Activity Type | Completion Events | Required | Algorithm | Description |
WD-EXT-ACT | W1-CrAnyServiceHistComplEvtTyp | Optional | Create Any Service History The Required value source xpath needs to be configured: rawMessage/completion/assetLocationAssets/assetLocationAssetList/serviceHistories | |
W1-CreateOperationalRead | Optional | Create Operational Reading The required source xpath needs to be configured: rawMessage/completion/assetLocationAssets/assetLocationAssetList/measurements | ||
W1-MobileUpdateWorkedAssets | Optional | Update Worked Assets The required source xpath needs to be configured: rawMessage/activityId | ||
W1-RemoveNonTrackedAsset | Optional | Remove Non- Tracked Asset The Required value source xpath needs to be configured: rawMessage/completion/ assetLocationAssets/ assetLocationAssetList/ actionTaken | ||
W1-RemoveTrackedAsset | Optional | Remove Tracked Asset The required source xpath needs to be configured: rawMessage/completion/ assetLocationAssets/ assetLocationAssetList/ actionTaken | ||
W1-AttachComponent | Optional | Attach Component The required source xpath needs to be configured: rawMessage/completion/assetLocationAssets/assetLocationAssetList/actionTaken Required Value Source XPath Value: W1IN | ||
W1-InstallNonTrackedAsset | Optional | Install Non Tracked Asset The Required value source xpath needs to be configured: rawMessage/completion/ assetLocationAssets/ assetLocationAssetList/ actionTaken Required Value Source XPath Value: W1IN | ||
W1-InstallTrackedAsset | Optional | Install Tracked Asset The required source xpath needs to be configured: rawMessage/completion/ assetLocationAssets/ assetLocationAssetList/ actionTaken Required Value Source XPath Value: W1IN |
