Asset Installs and Removals
This section includes instructions to perform asset installs and removals.
Installing Assets
To install an asset:
1. Start the activity.
2. To install an asset, click the location.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipmentpage-installasset28.png)
3. Click
Install Asset.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipmentpage-installasset29.png)
4. Enter the
Badge Number of the asset to be installed in this location and click
Install.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipmentpage-badgenumber30.png)
5. The newly installed asset is shown in the
Installed pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-installedpool-img31.jpg)
To attach a component:
2. To attach a component, click the asset.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-attachcomponent32.png)
3. Click
Attach Component.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-attachcomponent33.png)
4. Enter the
Badge Number of the component to be attached and click
Attach.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-badgenumber-img34.png)
The attached component is shown in the
Installed Pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-installedpool-img35.png)
To move an asset out of service:
2. To move an asset
out of service, click the asset.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-clickasset-img36.png)
3. Click
Out of Service.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-outofservice-img37.png)
4. Enter the
effective date/time and click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-effectivedate38.png)
The asset moves to ‘out of service’ status in
Deinstalled pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-deinstalled39.png)
To remove an asset/component:
2. Click the asset/component to be removed.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-remove-img40.png)
3. Click
Remove.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-page-remove-img41.png)
4. Enter the
submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-effectivedate-img42.png)
The asset/component is removed and moved to the
Deinstalled pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-deinstalledpool43.png)
To undo the installation:
1. To undo an installation, click the newly installed asset in the
Installed pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetsequipment-undoinstall-44.png)
2. Click
Undo Install Asset.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetpage-undoinstallasset45.png)
3. Click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetpage-submitundo-img46.png)
The asset/component installation is undone and it disappears from the installed pool.
To undo a newly attached component:
1. To undo attach, click the newly attached component in the installed pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-undoattach-img49.png)
2. Click
Undo Attach Component.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetdetails-undoattachcomponent50.png)
3. Click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetdetails-submitundo51.png)
4. The attach operation is undone and the component disappears from the installed pool.
To navigate to the parent asset:
1. To navigate to the parent asset, click the newly attached component in the i
nstalled pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-undopage-gotoparentasset53.png)
2. Click
Go to Parent Asset to navigate to the parent asset to which the component is attached.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-undopage-parentassetpage54.png)
To undo an asset removal:
1. To undo remove, click the removed asset.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-clickremovedasset.png)
2. Click
Undo Remove.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-undoremove.png)
3. Click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-submitundo-img57.png)
The removal is undone and asset disappears from the deinstalled pool.
To move an asset back to service:
1. To move asset back to service, click
Asset in
Out of Service.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-outofserviceasset-img59.png)
2. Click
Back to Service.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetequipment-page-clickback60.png)
3. Click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetequipment-page-clicksubmit61.png)
The asset moves to the Existing pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetdissapears-img62.png)
To replace an asset:
1. Click the asset that needs to be replaced.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assettoreplace-img63.png)
2. Click
Replace.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assettpage-clickreplace-img64.png)
3. Enter the badge number of the asset to be replaced with and click
Replace.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-asset-badgenumber-img65.png)
The new asset moves to the
Installed pool and the replaced asset moves to the
Deinstalled pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-newassetmoves-img66.png)
To replace the component:
1. Click the component to be replaced.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-clickcomponent-img67.png)
2. Click
Replace.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-clickreplace.png)
3. Enter the badge number of the replacing component and click
Replace.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-enterbadgenumber-clickreplace-img69.png)
The replaced component moves to the deinstalled pool and the newly attached component moves to the installed pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-replacedcomponentmoves-img70.png)
To undo replace an asset:
1. Click
Installed Asset/Component.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-clickinstalledasset-img71.png)
2. Click
Undo Replace.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-assetpage-undoreplace-img72.png)
3. Click
Submit.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-submitundoreplace-img73.png)
The replaced asset moves back to existing pool.
![](../WACS-OFS_SETUP_GUIDE_22B/images/useroperations-replacedassetmoves-img74.png)
4. Repeat the above steps to undo replace for a component.
