Property Name | Sample Value | Description |
os.namespace | The Object Storage namespace serves as a container for all your buckets and objects. Define the namespace where the buckets and objects the GL extract file resides. This is used when calling the Object Storage APIs. Shared property for all flows in this integration. | |
os.gl.bucketname | Bucket Name to where the objects or files are stored. Define the bucket name where the GL Extract file is stored. This is used when calling the Object Storage APIs. | |
gl.extract.filename.prefix | GL Extract file name prefix This should have the same value as the batch parameter filename in Batch Process C1-GLFCX. | |
os.apreq.bucketname | Bucket Name to where the objects or files are stored. Define the bucket name where the AP Req Extract file is stored. This is used when calling the Object Storage APIs. | |
apreq.extract.filename.prefix | The AP Req Extract file name prefix. This should have the same value as the batch parameter filename in Batch Process C1-APFCX. | |
os.prefixtag.fileuploaded | Uploaded | The text to append to the Ap Req Extract filename to mark the file as processed or uploaded in Object Storage. Shared property for all flows in this integration. |
apreq.input.directory | Folder path in which AP Request file is generated for CCB on-prem scenario from which OIC picks and process file to ERP | |
gl.ftp.input.directory | Folder path in which GL Extract file is generated for CCB on-prem scenario, OIC picks and process file to ERP from this location | |
ftp.download.directory | Stage directory in OIC to process the files downloaded from CCB server folder |
