Managing Catalog Services
The catalog service is used by Oracle Integration Cloud to communicate with the respective application. It is configured in Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog service in Oracle Utilities Customer Cloud Service:
1. Login to Oracle Utilities Customer Cloud Service.
2. Navigate to the Web Service Catalog page either from the Admin menu or the Search menu.
The external system and inbound web services mentioned in the table in step 3 are added to the catalog.
3. To get the catalog URL, append “webservices/builtin/ServiceCatalog?wsdl” to the on-premise application.
Example: http(s)://<C2M_HOST>:<C2M_PORT>/<ContextRoot>/webservices/builtin/ServiceCatalog?wsdl
If using Oracle Utilities Customer Cloud Service, the format should be: https://{host}:{port}/{tenant}/{domain}/{appName}/soap/api/iws/ServiceCatalog?WSDL
Following is the list of artifacts to be included in web service catalog:
For more information about configuration, refer to the Oracle Utilities Customer Cloud Service documentation. The documentation is available on Oracle Help Center at:
