Taking the Backup of an Existing Package
Before importing the new package, you must take the backup of an existing package which has all your customizations.
To take a backup of an existing package:
1. Login to Oracle Integration cloud.
2. Navigate to Integrations > Package.
3. Search for the “ccs_ofsc” package.
4. Click the icon and select Export. The selected package will be downloaded to your local machine.
To take a backup of existing lookups:
2. Navigate to Integrations > Lookups.
3. Search for the “SOMOFSC” lookups.
4. Click the icon and select Export to CSV. The selected lookup file will be downloaded to your local machine in .CSV format.
